dradeng
Jun 30, 2021Explorer
RV generator won't run and leaks when priming
I just replaced my fuel pump and fuel filter. After priming for 45 seconds the generator ran for about 2 minutes then stopped. Afterwards it would not run as seen in the video below. Before replacing the fuel pump and fuel filter the generator didn't run at all because close to no fuel was getting to the generator. Now when priming the fuel comes out but kind of in spurts, is it suppose to be a consistent stream?
I noticed when I prime the generator it seems to be leaking. I can't tell from where but could this be the problem? I attached the youtube video of where it kind of leaks from. Anybody know why/where it would leak?
Things to note:
Gas tank is half full
Carburetor was cleaned out a few months ago
Priming RV Generator leaks:
https://youtu.be/R-yb0ha5VS4
Trying to run RV generator:
https://youtu.be/hc3ZhmFtdjY
Things to note:
