MrWizard
May 25, 2021Moderator
The RV in the signature picture looks like a Fleetwood, Bounder
The 5 watt panel is just to tickle (yes tickle Not Trickle) the engine battery when the RV is in storage, if you use disconnect switches by the door when storing the RV,you probably won't even notice not having it
If you have shore power available or run the generator once a month for upkeep maintenance, the BCC will keep both house and engine batteries charged, it will also do this when the engine is running, BCC battery control center, black box under front hatch/hood with relays and fuses, the power center for 12v RV wiring that is not chassis and not part of living area, jacks, seats,steps,slides, etc..
A tree branch broke the wiring on my 5 watt panel, I full time, I have not bothered to replace that panel
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
