StuartT
Aug 13, 2018Explorer
Problem solved. After not seeing B+ at the VIM, I started working my way back through the incoming harness. Didn't take long before I found a 10 gauge red wire broken out of a two pin connector. When I remade the connection, to my great relief all systems fire up and the coach started. The shift selector lit up and all warning lights went out. I later traced that 12V transmission supply wire to a board in the Rear Run Bay, not direct to the chassis battery as expected.
