Gdlow's avatar
Gdlow
Slide issue
Had slide checked for squareness, etc. then installed guardian plates on the underside. Took it this AM to have tires checked and the slide had moved out about 1/2in or less.
it is the Rear slide...RBW slide..and yes appeared to go out just a little as stated...goes in and out normally.
one more edit...just appears to go out on the bottom of slide...not top
Issues...fix...???
  • Thanks... I will check that
    Couple of questions..will it travel ok like that or not?
    Where would the lever be? I can get to motor fine, but not sure where lever would be?
    Since it stays tight at top seems like a brake kinda issue...but that is coming from me a rank novice in most things mechanical
  • RBW used 2 motor types. One type has a built in brake and has a manual brake release lever. IF that lever was jolted to unlock your slide will do what you are experiencing. One quick way to determine if you have a brake lock unlocked----- retract the room fully and release the button. If the brake is unlocked, the room will relax and move out an inch or so at the bottom. Doug
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
