CT_WANDERER
Jan 04, 2015Explorer
Solar Panel Disconnected from SUN
I am planning installing 4X140W panels(parallel)flat mounted going to 15A breakers(so they can be switched off if needed) to the charge. The panel have ISC of 7.50 each times 4 equal 30. The controller(Blue Sky 3000I) I want to use has ISC rate of 24A, however they say it will work up to 30A. So would my panels only reach this 30A on ideal conditions? Or will I be pushing the 30A limit a lot? If I could hit more than my 30a limit could I just shut off on breaker? And if I open one breaker to the solar panel from the controller would it case damage to the panel sitting in the sun and not being used? I plan on installing breaker on both sides of the controller Blue Sky seems to make it a point of having a way to shut down and turn on power to the controller? I am new with this and still trying to figure out how I want to install my system or if I need to make changes to my plan before I buys stuff. Thank for any information given.
