โJan-07-2020 02:54 PM
โJan-12-2020 02:05 PM
BFL13 wrote:naturist wrote:
You will note that they have MC4 connectors on them. Those connectors are one male, the other female. It is impossible to connect them wrong because of the MC4 connectors. That is why they are there in the first place. But also, a VOM will confirm they are wired correctly.
If you use the clips as I linked above, and put them on the wrong wires going to the controller, you can end up with them reversed. Those little monsters take a bit of figuring out. ๐
Once they are on you can't get them off either. The pin grabbers mean once in, they stay in. It is an IQ test. If you fail the IQ test you buy more clips!
โJan-09-2020 01:36 PM
crcr wrote:BFL13 wrote:crcr wrote:
Thanks to Everyone for your prompt responses! Much appreciated. I will take the panels into the sun today and use a volt meter to verify that the MC4 connector with the red ring is positive.
The OP must have got sun-stroke and zapped himself as well, or we would have heard back by now how that went. ๐
LOL, no sun stroke. I got a chance to test one of my three Renogy panels, and as expected by my many helpful friends on this forum, the pigtail with the red band is in fact, the positive lead. As is wont to happen, life then intervened and I didn't get a chance to test the other two panels. Most likely the polarity is the same on those as the first panel, but just to be thorough, I will test the other two panels tomorrow and report back.
โJan-09-2020 09:08 AM
crcr wrote:
I have another related question and since it is about the mounting of solar panels on an RV roof, I will ask it in this thread rather than start a new thread.
I have stainless steel hardware to fasten the solar panels to my RV roof. Since stainless steel is known to sometimes gall, would it be wise to use a little bit of Anti-Seize on the SS nuts and bolts when assembling them? The pic below is of some copper-based anti-seize that I happen to have.
โJan-08-2020 06:01 PM
โJan-08-2020 05:50 PM
โJan-08-2020 04:23 PM
โJan-08-2020 03:54 PM
โJan-08-2020 12:44 PM
โJan-08-2020 09:54 AM
BFL13 wrote:
Yes the MC4s unsnap easily, but the metal pin in the ones I showed that you have to assemble onto a wire, have those little one-way grabbers that don't come back out once you shove them in.
The links I gave show a photo of the metal pin with its little grabbers, which keep the wire from being pulled out of the MC4 once assembled.
There might even be a proper name for what I am calling "grabbers" ๐
โJan-08-2020 06:33 AM
โJan-08-2020 04:20 AM
โJan-07-2020 07:14 PM
โJan-07-2020 07:06 PM
โJan-07-2020 04:27 PM
