mgfiest
Jun 06, 2015Explorer
Solar Panel with Deep Cycle Battery for winter storage
I have 1 12 volt deep cycle battery hooked up to a 30watt 15amp solar panel it has a shut off mechanism when it reaches the full charge state. I used this to keep the battery charged when not in use. I check the voltage at least 1 a month and it ranges from 12 - 13 volts, so it appears to be keeping it charged. The winters get very cold in ranges from -10C to -30C maybe at 1 week intervals but it does warm up to break those big freeze. I go and check the voltage on the battery and it still states 12 volts.
The issue is when I go to use it with the load in the spring I get a quick drop in voltage, I can not use the battery to start the fridge which needs at least 10v.
Is there somehting missing in my charging?
