allen8106's avatar
allen8106
Solar Postive Battery Connection
Hey guys. I'm in the process of putting the final touches on my 5er solar project. 4 Kyocera 130 watt panels, Morningstar TM-45 Charge Controller, Bogart TM-2030 Battery Monitor, Magnum MMS1012 inverter and 2 Crown CR-240 6 volt batteries. I may end up adding two more batteries later but for now the pair will suffice.
One of the things I'm struggling with is the number of connections to the primary positive battery post. I still need to attach the inverter postive connection and I'm running out of room on the post.
Any suggestions?
