PaoliExplorerJul 18, 2016Solar Question.Question: When I shut off the battery with the "shut off" knob inside the motorhome and park the vehicle for awhile, will the solar panel still charge the batteries?
MudChuckerExplorerJul 18, 2016Only you will know... it could be either way....unhook the battery terminal cablesplace the switch in the off positioncheck the battery terminal cables for possible voltage from the solar gear.make sense ?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
Related ContentFactory Solar QuestionMore solar questions!Solar install questionLance roof solar plug questionsolar charger questions
