joe0508
Apr 12, 2015Explorer
stripped nut
I have a battery post that i cant loosen or tighten.It is loose and i cant tighten it down.Does anyone have any suggestions on what i need to do to get the bolt off?
Ron3rd wrote:
I would cut if off with a small cutoff wheel like a dremel and start over.
lanerd wrote:I am not talking about the part that clamps around the battery post.There is a threaded screw that is made on the clamp that goes on the post.The wires go on this screw with a nut and it wont tighten or loosen.If i could get the nut off all i will have to replace is the clamp.
I'm a little confused. I assume that since you can't tighten it down, that the terminal is off of the post and the bolt is one that goes through the prongs of the terminal that will tighten around the post with the bolt. If this is the case, I would put a wrench on the head of the bolt and vice grips on the nut and pull upward (or outward) while turning counter clock wise. If that doesn't work, I too would try to cut the bolt in half between the terminal's prongs.
Hope this helps
Ron
lanerd wrote:Ok thanks,I will try to pry it off first before going the splitter route.Thanks for the help.
Ok, I edited my reply...please excuse my confusion. Like I said, I would still use the vice grip method and if it didn't work, cut the threaded post off and buy a new one.
Ron
