โDec-24-2018 08:37 AM
โDec-25-2018 11:47 AM
Lynnmor wrote:MEXICOWANDERER wrote:
Anodic Cathodic action works using water as the electrolyte medium or perhaps it is supposed to function somehow in a glass lined tank?
The glass lining can be less than perfect, and there is no glass protecting the steel at the various threaded fittings.
Since Atwood uses an aluminum tank that acts as an anode how much metal is lost? Do they ever become porous from that action?
โDec-25-2018 11:46 AM
jodeb720 wrote:
Good catch on the anti seize not being good for my health!
I will be chasing the threads clean anyway - I don't want a problem in the future.
Doug, do they sell rector seal in the big box stores or is that only an online item? I'm leaving on Wednesday and would like to install this today (once the replacement arrives - thanks Amazon!)
Thanks to all for the quick replies.
josh
โDec-25-2018 09:58 AM
dougrainer wrote:
Rector seal 5 BEST stuff to use. I use it on threaded plumbing AND 3000 psi hydraulic jack threads. NEVER had a leak in 25 years and does not seize the threads. Doug
https://www.sears.com/rectorseal-no-5-pipe-thread-sealant/p-009VA92867312P?sid=IDx20141028xBingPLA&s...
โDec-25-2018 05:55 AM
Dave H M wrote:
Well here is my take. I ordered an elcheapo tap off ebay to chase those threads if and when necessary. I leave the rod out when the trailer goes into long storage with a smidge of plumbers grease on the threads that I apply with my pinkie.
And I do use teflon tape on the install.
โDec-25-2018 05:41 AM
โDec-24-2018 05:28 PM
โDec-24-2018 05:20 PM
ScottG wrote:
I would (and do) use teflon tape. Never leaked and easy to remove and reseal next time.
โDec-24-2018 04:08 PM
midnightsadie wrote:
and it don,t need to be gorilla tight. just good and snug.
โDec-24-2018 03:35 PM
โDec-24-2018 02:39 PM
MEXICOWANDERER wrote:Just an FYI, from the Suburban website:
โDec-24-2018 12:26 PM
โDec-24-2018 12:21 PM
โDec-24-2018 12:11 PM
donn0128 wrote:You're probably right about the anti-seize not being good to eat, but I never ingest water from the water heater. That's not a good idea anytime, even at home, because of the build-up of mineral deposits.
Antisieze is more than likely not good foe your health. Teflon tape is the preferred product.
โDec-24-2018 11:21 AM
โDec-24-2018 11:15 AM
jodeb720 wrote:
I know if I wrap the threads in teflon tape, there's a good chance, it'll isolate the rod and that will defeat the reason to have the Anode in the first place.
