BFL13's avatar
BFL13
Jan 23, 2019
Swap 12v for 120v Fridge Element? UPDATE 2
EDIT--it turned out you can't swap them--they are not the same and it would fry things if you applied 120v to the 12v element
UPDATE 25 Jan--12v is cooling down the freezer.
UPDATE 2, 26Jan
I found my 120v heating element that was not working to be rusty and it and the 12v element beside it are both rusted to the coil pipe (or whatever the assembly is supposed to be like ????)
I was poking with a screwdriver and it cracked open or made? a fault in the 120v heating element pipe that is rusty dark. the 12v element beside it looks identical but is shiny--maybe never used.
It would be easy to swap the wiring so that the 12v element's two wires went to the terminals on the board that the 120v element's wires go to now. Only thing would be to eliminate the 20 amp fuse on one of the 12v elements wires.
But--are these two elements the same so I can do that?
Photo shows the 120v on the left of the 12v element which is the shiny one to the right of the photo.
