Jkdstar's avatar
Jkdstar
Tank level indicator wiring
Water Tank Indicator wires. I can't find the diagram for what color wires attach to which holes in the actual water tank? I have 6 rubber holes coming from the tank with a 3 hook red wire not attached to anything (guessing ground of some sort). And then a Yellow, Orange, Red, Grey, and Green coming from the wall (I'm guessing the switch that runs the pump by the sink. Or do the colors even matter which one is in which hole?
  • j-d's avatar
    j-d
    What is the brand of the Monitor Panel? If it's a KiB, that company used to publish a lot of support info. Seems they've "cleaned up" their web, I couldn't find much.
    Try gOOgle "kib monitor panel wiring diagram k-21 2f" without the quotes, you can experiment from there, changing that search a little here and there.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
