Has anyone used a residential type wax ring on the floor for there thetford RV toilet. I can't seam to get the foam gasket to seal. The one that came out was about 1/2" thick and the replacement was...
The wax seal will fail due to vibrations while underway. The wax will be compressed away from the toilet outlet, and has no resilience to expand back into place. Make sure you're using the correct seal for your brand/model toilet and that the mating surfaces are clean for a good seal. Proper tightening of the base bolts is also important. Follow the manufacturer's installation instructions.
