WE-C-USA
May 13, 2017Explorer
I got everything the way I want. Moved the hot gen/inverter wire from L2 to L1. Transfer switch worked without jumper. I then reversed the L1 & L2 ( Black-Red) to the control panel (output) side.
How I only power the things I want too.
The main reason I don't want to power one side, it has- Water Heater-AC-Convertor & some outlets, things that are not used while using the 2000w inverter. I wanted the converter off while using the inverter/charger/generator. I use a Honda 2000 mainly to recharge batteries.
