Old-Biscuit
May 07, 2015Explorer III
No need to buy a 3/4" TAP............just buy a 3/4" NPT Steel Nipple
Remove anode rod......then run nipple in until resistance then back out then in further/back out,,,in further until very snug.
Drain plug threads are steel and using the steel nipple will clean up the threads.
Remove nipple......turn on water supply and blow water out drain hole. Turn water off.
Wrap anode rod threads will several wraps of teflon tape.
Using a 6 point socket w/extension install rod and hand tighten.......then snug down tight .
