JRRNeiklot's avatar
JRRNeiklot
Trimetric 2030 battery monitor
I'm in the process of installing my solar setup. I have everything installed except the solar panels. I am having issues with my Trimetric 2030 battery monitor. After charging to 95%, according to my battery charger, it's showing 14.5 volts, both at the charger and the Trimetric, but the amps are showing negative .3, which is the draw of phantom loads, I assume. It shows the same -.3 when I'm not charging. It should be showing the amount of amps incoming, correct? I discharged the batteries to 12.3 volts today - my battery charger was showing 62%, but the Trimetric shows the battery perentage at 98%. Can anyone help me straighten this out?
Thanks.
