Big_Katuna
Jul 07, 2016Explorer II
UPDATE Power Gear slide out motor gone
I took the coach to Robbins RV in Ormond last week and the slide is fixed. They were prompt, gave me a discount off of retail for the motor and one hour labor later its fixed.
When I came to pick it up, it was parked under a covered building.
I highly recommend them.
2005 Fleetwood 38N (three slide DP).
So this past weekend we went camping over the 4th.
Went to put living slide out; I hit the out button for a few seconds, slide started to go out, then I stopped to move my seat up as it interferes. That was all she wrote. Never moved again. We camped with one slide in.
I assumed it was a motor gone bad; the kitchen slide was replaced a few years ago.
About halfway home we stopped for fuel and a trucker said he saw a cable dragging. I looked and it was long enough to hit the ground midships. The drivers son volunteered to crawl under and try to plug it back in but couldn't find anywhere to plug it so as not to tie up space had him secure it so it wouldn't drag. Looked like a 6 pin Molex type nylon connector.
I was hoping it had just came unplugged and just had a friend stop by to see if he could plug it in and he reported that the motor and most of the case was gone! You can see the gears and the housing that holds the shaft bearing is there and not much else.
So my questions are for those of you who have replaced their motor; it looks like most motors on Ebay just have a few wires coming out.
I called Fleetwood last week when this happened and their motor was $630 plus shipping. Ill call back and ask for schematics and ask if the motor come with a plug ready to install or what else I will need to fix it.
I will look at the rear slide tomorrow to see what I can learn as well. It can be accessed from the inside.
I will keep the thread updated.
