- BobboExplorer III replaced the MagnaJunk 7345 in my old Winnebago with a PD4655V from Best Converters years ago. I sold my Winnebago last month and bought an Airstream. The Airstream comes with a Parallax (aka MagnaJunk) 8355 converter. It will be delivered next week, and I have a brand spanking new PD4655V from Best Converters sitting in the garage even as we type. The 8355 will never even be plugged in at this house.
YMMV - -LqdskierExplorerThat sounds like a great option, Bobbo. Do I need any additional components or is the kit complete? I pretty sure mine is the 6300 series.
- D_E_BishopExplorerI don't know enough about Magnatek converters to say they are junk but I do like how the PD series work better than my Magnatek Model 7445. I also though that the PD Wizard was unnecessary until I installed one in my 1990 Bounder. Now I to plan on replacing the Magnatek as soon as I finish the new planter in the front yard and replace our entry doors. At that point our remodel will, for me at least, be complete and hopefully free up some of our expendable income.
I did not go through BestConverters for the upgrade for the Bounder but I will for the replacement for the Magnatek. The Magnatek cooling fan is very noisy in comparison to the PD, I can hear it without having my hearing aids in.
I just posted my reply after your replied to Bobbo and Chris replied to you, I cannot remember the name of the guy at Best Converters but I do know Chris from posts here on RV.NET and respect his judgment. I'd call BC and ask which is "best, easiest and fits your budget and needs". Ask about the 8300 series at that time. - Chris_BryantExplorer II
YMMV
Umm- you do know that the 8300 series has the option of temperature corrected 4 stage charging- something the PD doesn't offer?
The 6300 and 7300 series are not good, but the 8300 series is different. - BFL13Explorer II
You need to "jumper" the 6300's fuse panel to use it with a newer converter, or you can buy a new fuse panel that works with the 7300 or others.
Beware of the upgrade kits 7300R and Ultra which get you a 7300 or a WFCO (unsat) You can get an upgrade using PowerMax or PD for less money and have a way better converter.
I disagree with Bobbo and the 7300. Works great as a shore power converter and ours has lasted years and years (2002 built rig) I use different chargers for fast charging with generator power off grid though. Single 13.8v from the 7300 is not enough for that job. - BobboExplorer II
The kit is complete. It even comes with a new 12v distribution board that has the charge wizard built in.Chris Bryant wrote:
YMMV
No. Please educate me. I am not above returning the PD4655V. The Parallax website has nothing on this. Bobbo wrote:
http://www.parallaxpower.com/8355-power-center-8355
Special Features:
30 Amp Shore service; 11 Position fuse block with blown fuse indicators; TempAssure option ready; durable steel enclosure
http://www.bestconverter.com/8300-Series_c_87.html- Chris_BryantExplorer IIOwners Manual
Forum is being broken- trying to quote from that, but look at the optional TempAssure module, which I assume Airstream would include, given that they don't really give those things away :) - ScottGNomadYou are far better off with the PDI unit.
- BFL13Explorer IIThe 8300 appears to have a 4400 as its lower portion instead of the 7300. I had a 4455TC and it was very good (until I accidentally fried it--RIP!)
However, unless it has the TempAssure module in it (it just plugs in--easy!) it will not do the half volt jump for boost, so it is about same performance as the 7300 (also good for a single voltage 13.8) as is. If you get the 4400 with no TempAssure, be sure to get one--BIG DIFF in performance.
http://www.bestconverter.com/Parallax-Paramode-with-TempAssure_c_104.html
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
