racer4's avatar
racer4
Use DeoxIT Spray On Power Post Outlet?
When I get a RV site with a suspicious looking power post outlet, is it good to use DeoxIT D5 or DN5 spray to clean the outlet terminals?
What I mean by suspicious is not broken, but old and worn. Getting a different RV site is often not practical. So what can I do to make the best of it? I don't want to end up with burnt prongs on an expensive ($80-$150) power cord.
If using DeoxIT is good, which version should I buy?
DeoxIT D5 says to let it dry for 2 to 3 minutes and it says the solvent is flammable.
DeoxIT DN5 says "May be used where fast evaporation and/or non-flammability is required, and no dripping is preferred. It is also safe on plastics." I wonder if it cleans as well as D5.
DeoxIT® Directions For Use pdf
