familyof3ExplorerAug 23, 2015Using WFCO 75 amp to charge batteriesCan you use a WFCO 75 amp converter to charge a car battery? It would be the same as using it in the rv wouldn't it? I'm guessing also it is a one stage charging source of 75 amp charge. Thanks fo...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 17, 2025
Related Contentbattery chargingBattery/ charging questionBatteries not chargingBattery charging questionBattery Charging
