USXplorer's avatar
USXplorer
Water Heater Flush?
Has anyone flushed their water heater with vinegar or other similar non-toxic solution to de-scale and de-lime the interior? Is it recommended and did it work? What did you use and how did you apply it? (through the anode access?)
  • I use the anode hole. After you get it in shape I just use water, nothing else. But I usually flush out 2 or 3 times a year. The newer clean out tools are now plastic. If possible get the copper tube model or make one yourself. I was able to aim and clean out better with metal tube than plastic tube. Lots of videos and info about it. I keep mine stored inside water heater door along with spare anode.
    I do mine when water is cold...sounds simple enough...but I learned that one by mistake the hard way. Hot water really is hot:) Many times I also sanitize afterwards. I usually replace the anode if 1/2 gone or better.
    After you think you are done...fill up 3 clear glasses of water and let sit on table for couple hours. Then look real close at glasses to see water is 100 percent clear and no little creatures on the bottom. Like little calcium crums. Reason to check is those little crums make their way to water pump and faucets. Not your best friend.
  • Atwood has a vinegar soak procedure in their WH Manuals
    Drain water heater.....re-install drain plug
    Remove T&P Relief Valve
    Pour 4 gallons white vinegar into WH Tank via T&P Relief Valve opening
    Pour 2 gallons water in
    Re-install T&P Relief Valve
    Turn WH ON and let it heat/cool for 4 complete heating cycles
    Then drain/flush
    4 gallons vinegar to 2 gallons water is for 6 gallon WH
    Adjust accordingly for larger capacity tanks
    When draining/flushing I prefer to do a 'power flush'
    Turn water supply OFF
    Remove drain plug
    Then turn water supply back on full force and let it BLOW out thru drain hole
    Turn water Off....ON until crud is blown out
    Those 'cleaning wands' take up too much of drain hole especially Atwood's 1/2" diameter drain hole
  • I used the standard water flush tool from Walmart. I got some sand and debris from bottom. Did not see any scaling.
    It only takes a few minutes during winterizing. I do it during winterizing so if any debris is present it should be soft and wash out easier. If I wait until spring it could have hardened over the winter.
