Teleman's avatar
Teleman
Water heater not working
I just bought a 2000 Airstream Land Yacht and the water heater isn't working. The light doesn't go on when I turn the switch on. The fuse in the panel is good. The switch on the unit is on. There is water in the unit, valves open, etc. Shouldn't the light at the switch go on even if the mother board was bad, or there was some other problem at the water heater?
