cannesdo's avatar
cannesdo
What does this burned furnace wire tell you?
While trying to figure out if my brake controller was alive I think I shorted something out. Furnace isn't turning on. A/C and fan do still work. Found this burned wire front and center when I took the furnace cover off. The blue wire connected to the left side of the pink connector leads to the control board. If the board is fried can you see it? And isn't there a fuse in the furnace (back behind)? If so, what is the path the current travels? Does the location of this wire tell you anything about what else is likely affected?
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
