CarnationSailor's avatar
Jul 22, 2018
What is Normal Brake Wear?
I have a 2015 Crossroads Rushmore Springfield 5th-wheel. (36-foot with dual axles.) I had the wheel bearings repacked, brake wear checked, brakes adjusted, and tires rotated at 7,500 miles (at Les Schwab). I was told that the brakes were in good shape, but should have them checked every time I have the wheel bearings repacked.
At 15,000 miles, I took the trailer back to Les Schwab. (Note: It was my intention to have the bearings repacked every 6,000 miles as recommended by Crossroads; however, I postponed the service both times due to being on the road and not wanting to trust a service center far from home.)
This time i was told that the brakes shoes were beyond worn out and had scored and caused "hot spots" on all four drums. I needed new electric brake assemblies which included new shoes and new magnets, new drums, and new bearings and seals. Had the condition of the shoes been noticed sooner, I would have been looking at around $1100 for new brakes. Instead, it cost me around $2400.
Les Schwab came up with various ideas as to what could have caused the damage (stuck shoe, stuck magnet, etc.), but all made sense for only one or two wheels and made no sense for all four wheels.
Obviously, I will have the brakes checked more often in the future, but I do have some questions:
Is it normal for brakes to wear this quickly? If not, what could have caused premature wear? (Note: I would have expected the wear to be less than average as I always use the exhaust brake going down grades and rarely have to use the brakes.)
How often do others check for brake wear?
Thanks
