โJun-05-2013 01:46 PM
โJun-06-2013 10:42 AM
โJun-06-2013 10:10 AM
โJun-06-2013 04:42 AM
rtate wrote:
I think what I will do in the morning is to run a wire directly from the battery to the frig. And see what happens. If it runs with no problem then I know the problem is in the eyebrow. Will let ypu know in the morning what happens
โJun-05-2013 05:41 PM
โJun-05-2013 05:05 PM
prolandsurveyor wrote:
Sounds liked got a bad ground but it's hard to diagnost on the internet
โJun-05-2013 04:58 PM
โJun-05-2013 04:37 PM
โJun-05-2013 02:19 PM
โJun-05-2013 02:16 PM
rtate wrote:
I pulled out my Norcold refrigerator to replace a vent fan on the back. I tested out everything prior to slidong it back into its opening and things seemed to work fine.
After slidong it back in place i couldnt get it to turn on, so I started checking things..
No 120 volt power hooked, just 12 volt.
Where power goes to the frig I only got 5.7 volts. I disconected the the 12 volt power feed and checked power at the feed without being hooked up to the frig. I got 11 volts. At the battery I got 13 volts.
Looks to me like I have two different problems. First the power drop from the battery to where it feeds the frig. I need to trouble shoot that, but why the heck am I getting a 5.7 volt reading when hooked up to the frig? Not sure I know where to start. I disconnected the connection to the eybrow but didnt seem to make any difference.
HELP!!!!!
