โJun-09-2017 06:33 PM
โJun-10-2017 11:48 AM
โJun-10-2017 11:03 AM
โJun-10-2017 09:36 AM
Lantley wrote:
In the end the toilet had a bad o ring seal that the OP was able to fix. Does that mean the entire line of toilets is defective and should be recalled?
If so where are all the other complaints?
Doug's point is the Dometic sky is not falling. Condemning the entire series based on 1 toilet is a bit of an over reaction.
Doug is in the business and deals with way more than 1 or 2 toilets a year.
He has a broader more global perspective. I imagine he is somewhat perturbed by the overblown exaggerated post. While I have nothing at stake here I understand Doug's point.
โJun-10-2017 09:23 AM
โJun-10-2017 08:26 AM
Lantley wrote:He has a one-year old TT. A quick Google shows reports of the recall as far back as 2013. Riverside is a small manufacturer - I doubt they were working off a 3+ year old supply of toilets.mike-s wrote:
Dometic has a history of bad seals, which allow waste to collect in places it simply shouldn't be. Whether from design or manufacturing, it doesn't matter, it's an issue.
So it appears maybe there has been a recall issued on 300 series toilet? The OP may want to contact Dometic on this.
โJun-10-2017 08:06 AM
โJun-10-2017 07:36 AM
โJun-10-2017 07:35 AM
โJun-10-2017 07:15 AM
โJun-10-2017 05:55 AM
โJun-10-2017 05:48 AM
dougrainer wrote:
Let me get this straight. Dometic makes hundreds of thousands of this model toilet. They are in scores of models. You have a DEFECTIVE one. So, you blame ALL the 300 toilets and the designer. Get a life. You fixed yours. Dometic sanitation have a 2 year warranty. If you go thru the proper procedure, they will replace your defective one. Doug
โJun-10-2017 05:41 AM
Bill.Satellite wrote:bucky wrote:mike-s wrote:
I think we just found out who designed it - Doug Rainer.
As much help as Doug is on here let's not throw stones. The rest of us want his input. At least use a smiley face.
Really? Why the smiley? I don't think he was trying to be funny. Some non-helpful posts need to be called out. RVing can be frustrating and I think it's OK to vent.
โJun-10-2017 05:23 AM
โJun-10-2017 03:15 AM
