wopachop's avatar
wopachop
Will snow damage your average toy hauler roof?
2013 Forest River Stealth. It snowed on thanksgiving and i left it for a couple days. Once i scraped it off i noticed the roof was visually concave between the supports.
Snowed again last night and wonder if i should climb up there or not.
Tried doing several searches and everything came up with zero results. Even though i know this must have come up many times.
Its around 6-8" of snow. This year has been more than normal. Most years we dont get any.
  • GDS-3950BH wrote:
    There are thousands of new RV's sitting on the manufacturers and transporters lots in Elkhart / Goshen IN, and on dealers lots. They don't worry about snow or clean it off. At the local Camping World they don't even run in slides, and they leave the bunks / tents deployed on hybrids.
    Well if Camping World says it's ok ......:B
    As a resident of the snow belt, I would not think about removing snow from the TT roof unless there was a LOT--like a foot and a half or so.
    If your roof is concave, it seems like you may have a problem. Has the unit ever leaked in the past?
  • There are thousands of new RV's sitting on the manufacturers and transporters lots in Elkhart / Goshen IN, and on dealers lots. They don't worry about snow or clean it off. At the local Camping World they don't even run in slides, and they leave the bunks / tents deployed on hybrids.
  • Odds are if the snow weight made the roof concave between the supports, your roof has been leaking for a while and the wood is rotten. I would get as much off of it as possible and put a tarp over it until it warms up. It wouldn't hurt to put some plywood under the tarp to help spread the load over the supports so water weight isn't laying in the low spots.
  • You could run a heater in there for a couple days to melt that snow. I agree that the freeze/thaw cycle is probably the worst worry.
    As of late, I've started covering my trailer in the winter with shrink wrap over a peaked center ridge that causes snow to run off.
  • You'll probably do more damage with the shovel than the snow will. I don't worry about my TT or MH.
    Bill
  • wa8yxm's avatar
    wa8yxm
    Depends on many things but if it's many inches of wet heavy snow.. POSSIBLE. if it's a couple inches or just light power no it won't.
    Consider this. on my class A 2x a year I walk all over the roof with mop (Well long handled van wash brush) Bucket, Hose, Spic and Span and my size 12 gun boats. I'm 300 pounds shower weight so about 315 on the roof... So far the only holes in the roof are the ones that the maker put there (A/C, Vent lines. Air vents, that kind of thing )and one of them is gone (Long story it's for a sat antenna feed)
  • Snow will collapse any roof. The determining factor is how much and how wet. My limit is a foot. Then I remove.
  • Never had a TH, but in my experience, even several feet of snow has never caused an issue. I'd be more concerned about the freeze/thaw cycle maybe causing cracks to open up in the sealant/caulking. I do push snow off, when weather warms, as the melting always starts at the roof, under the snow.
    Jerry
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
