GENECOP
Nov 14, 2013Explorer II
Bumpyroad wrote:GENECOP wrote:Bumpyroad wrote:GENECOP wrote:
http://www.campingworld.com/shopping/item/no-fuss-flush/3495
yep but you also need the installation kit, hose, bracket mount, etc. the accessible location on my black tanks has been at the outlet area and you want the flush mounted on the side opposite it.
bumpy
We Have a Truck Conversion Class 8 MH.....MY HOLDING tanks are in an enclosed heated compartment behind a lower door, my NF Flush was easy to install and easily accessible for hooking up the hose ......Top of the tank on the same side as the outlet so the spray hits the back wall and sides of tank and washes everything out nicely....
that installation is directly opposite of the recommended one. would be better on the side opposite the drain to push stuff out and to break up the pyramid under the stool. I sort of gave up the idea of installing one on my new TT since the side opposite is buried. may look into installing one adjacent to the drain:????
bumpy
Hook up the hose to the No Fuss Flush before you install it... I don't think it matters where you place it, it is an intense shower blasting around your tank....if you google image Black Tank Flush Location you will see many examples of the install on the drain side....
