plessm's avatar
plessm
2004 Komfort 25 TBS
Hello. I'm looking for a trailer for my family. Wife and 3 boys, ages 15, 10, and 4. We are coming from an oldie, 1972 Timberline "Twenty-Two Six". It was my grandpas and it was in great shape. Just too small for the 5 of us. I've got $10k cash and don't want any loan. That means I'm buying used. Ive looked at a couple 26ish bunk trailers in the 2001 to 2005 range. None seem even close to being as well built as the old Timberline. Well i should say all but the Komfort I looked at. Huge frame, shock absorbers on the axles, big tanks, solid cabinets, good storage, etc. I really think this is the only make/model I want to buy of this age.
Grandpa had the Timberline since 1985 and my wife and I had it since 1998 when he and my grandmother quit camping. I've worked on just about everything in that trailer from pump to propane tanks to batteries, to axles, brakes, bearings, lights, toilet, water pipes, electrical, re butyl all windows, replace roof vents, etc, etc. I'm competent with repairs that are required, I would say up to medium level repairs.
With all this said, I'm scared to death to drop $8000 - $10000 on a 10 - 12 year old trailer. I've located a couple in the past couple months. I got underneath them with flashlight got in all cabinets and storage areas looking for any signs of damage or water leak. The roof is a big unknown for me. These rubber roofs, I've read about on this site but have no experience with. I've read of some repaired and some replaced and all require regular maintenance. If I go look at a 10 plus year old trailer, what should I expect in the roof? Will it most likely need to be replaced? Am I looking for cracks or separations at edges?
I'm new to slides as well. Will a 10 year old slide most likely need some sort of maintenance? And then what do you all think of Komfort? I started looking for Komfort after reading reviews here. The reviews I've read about the 25 TBS though are from 2008 or earlier but they are all good saying it's a high quality trailer.
Thanks for any help you can provide to someone looking to buy an older trailer. Oh also weight is not an issue, I have a 2006 Ram 2500 Cummins turbo diesel. Thanks!
  • plessm
    I have a 24 ft, but not a bunk. found my kids wanted to sleep outdoors.
    I have seen some on craigslist around here.
    if you will need a WDH, I have a new Equalizer 1200. purchased it for trailer, and then bought a 5th wheel. it is still in box. I am up in Stockton.
    both my units have slides, I ran them in and out to see if any binding. take a close look at the floor to see if any leaks. one thing about slider, when it goes out, make SURE the rubber seal turns correctly to keep out water.
    there is great info on this site on roof care.
    good luck
  • just saw this one
    http://modesto.craigslist.org/rvs/5469027392.html
    http://klamath.craigslist.org/rvd/5469739039.html
  • You probably will never find one as good as that old Timberline. Paul Keiper was known for building a real quality product. Komfort before the name was bought also had a decent reputation, but after they were bought out by Thor things went down hill pretty fast until they finally killed the name plate.
    You might look for a Nash or Arctic Fox. Northwood does a really good job building trailers. Except for a couple of years with delam issues very few problems.
  • I've been very pleased with my 2007 Komfort trailer. I've read a lot of information about Komfort having been bought by Thor and then quality went downhill but that most "rumors" seems to be spread from people who never owned them.
    Has mine been trouble free and maintenance free? No. I had an issue with my slide to where the main ground for the slide switch/motor was extremely loose causing issues with the slide inconsistently working, although ultimately that was an easy fix, just took a long time for me to locate the problem. Yes, I need to reseal the roof seams for preventative maintenance, but what box style trailer doesn't have to have this done?
    My trailer is of the heavier build with a single slide and GVWR of 9500 lbs. That is a 26' cabin, 30' overall length. Heavier yes but it is also very solid and seems very well built. So, I do not agree with the Komfort after Thor downhill comments. I intend to hold on to mine for another 5-10 years and will probably move on to a truck camper once the kids have moved out.
    Thanks for your reply, this is helpful. Funny you mention a truck camper when the kids move out, I'm thinking the same thing in 10 or 12 yewrs. Would like to pull a boat for fishing yet still have a nice comfortable setup for camping.
  • my 2006 24ft trailblazer is a after Komfort, and it to is fantastic. very solid, yes a little heavier, but I like the stability. these super light units do not have cargo capacity as mine, or the storage of mine.
    do not be to concerned about having to go with camper to pull a boat, unless very large.
    my new Ram 3500 and 30ft 5th wheel, and 14" jon boat and 2 kayaks on top of cab. carry a 7.5 motor on front of truck.
    also have been reading about this Idaho tote for behind 5er.
  • bbaker2001 wrote:
    ...do not be to concerned about having to go with camper to pull a boat, unless very large.
    I know this comment is probably more for the OP, but my reasoning for wanting to go with a truck camper is more about getting into harder to reach access areas where TT/5ths would not be able to get to. Think tight, multi switch-back non-paved roads. There is a fair amount of that in the Rockies but add that I would like to also pull my OHV trailer too. Just opens up the access for me a bit more than loading an ATV in my truck bed and pulling a 30' trailer.
    It is one reason why I am glad I have a newer diesel 1 ton with camper package that has a good amount of payload for trcuk camper capability. Yes, SRW long box and I would be looking for a truck camper not exceeding 2500 lbs so my choices will be limited.
  • Red, sorry did not mean to undermined your post.
    heck we saw a camper that when opened up was almost as big as my trailer. really nice
    I would love one for your reason also, but the DW doesn't think so.
    have a great day
    have a great day
    No man, did not feel of it in that way at all.
    Everyone has what is good for them and sometimes it is not so evident unless explained. Just felt I would explain my reasoning in a bit more detail.
  • another one
    http://stockton.craigslist.org/rvd/5478054220.html
    seems like great price
    2004 trail lite Dutchman $2500
    also noticed location is San Fran
