ACZL's avatar
ACZL
6.7 Powerstroke Oil recommendations
Just an FYI to newer owners of 6.7 Powerstroke. Not sure if anyone saw/heard this at all, but last month Ford came out and said not to use some brands of CK oils as it wasn't "meeting" certain Ford tests (namely wear if not mistaken). Upon reading this, I said to myself "WTheck?" Called to a maker of oil I use and have been using and it seems that the 1 type I want to use is 1 that "doesn't" meet Ford's criteria for now anyways. He suggested using a different type (blend VS full synthetic) as long as it's in warranty. The blend oil is CJ oil and full synth is CK. However, spoke to Ford dealer and he said it's just a bulletin and Ford cannot change the warranty in mid stream if your engine calls for CJ oil and all you can get is CK. Course he is saying Ford is recommending to use their oil., read $$$$$$$$$$
If others could chime in with opinions/ facts or other would be great.
