Cairn_terrier
Mar 31, 2014Explorer
Advice from current or past Livin Lite owners, similar TTs
We are about to become first time TT owners, basically seeking upscale backpacking quarters. We will travel very, very light and want quality construction over size. Lifelong backpackers, retiring to travel, hike, sleep in real bed, take our small dog.
Tow vehicle new 2014 Honda Ridgeline rated at 5000lbs gross max weight.
14db noted below is 2500 lbs, plus water, 500# max, plus a max of 500 of gear, mostly our very lightweight backpacking gear, miniature stoves, sleeping bags, etc. Target total weight of 3500#.
Questions: Comparing a Livin Lite 13db vs a 14db. I can see that we would get a bit more space/weight with the 14',and more cost.
Beyond that, what are your thoughts on these three specific items:
Single vs double axle. Is the double far superior and why? Does this indeed give me a huge margin of safety in the event of a TT tire blowout?
Wet bath vs dry bath. Is a wetbath a real pain? Wife will use this, I will most likely almost never use this opting for the outdoor shower 365 days per year.
Electric brake vs surge brake? Which is better and why?
Other CONSTRUCTIVE suggestions welcome.
Slams or criticisms that do not help me make a better decision ... not so much.
Thank you to kind replies.
