โMay-16-2014 09:24 PM
โMay-20-2014 12:08 PM
โMay-20-2014 11:37 AM
โMay-19-2014 04:42 PM
Moose10 wrote:
I just installed Bilstein 4600's (the yellow & blue ones) on my truck and oh what a wonderful difference. Ended up getting them from shockwarehouse.com since like thejustin said, Amazon won't ship to AK any longer.
โMay-19-2014 04:03 PM
โMay-19-2014 01:20 AM
ah64id wrote:
My recommendation is to have the bags at 5 psi, and. measure the height of the rear wheel wells. Then load the camper. Adding air to the bags get so it's 1-2" lower than empty, assuming no level kit.
I think you will find that is a good mix of weight on the bags and weight on the springs.
One thing, don't prefill the bags with a loaded psi, it could easily overinflated them once loaded.
Get the bags at the pressure you want loaded and then record, then you can unload and see what the pressure drops to. That would be your empty pressure.
With my load of about 3K on the rear axle I know that 10 psi empty gets me about 25 loaded and I am good. 7 psi empty gets me 15 loaded if I don't have a full camping load.
โMay-18-2014 10:07 PM
โMay-18-2014 09:43 PM
ah64id wrote:
Airbags, when plumbed independently, will reduce sway.
โMay-18-2014 12:11 PM
โMay-18-2014 11:36 AM
thejustin wrote:
Kind of leaning towards just skipping the lower stableloads and just using the Firestone airbags in conjunction with the existing upper stableloads that are one there. I was thinking about it last night and I gather the point of these is to preload the overloads because in many instances they won't even engage with a load in the bed, but I am just about at my max payload hovering around 4500-5000 lbs. in the truck bed. Shouldn't that be enough weight to sufficiently engage the overloads? Are the stabeloads even necessary with a weight that large?
โMay-18-2014 05:21 AM
sky_free wrote:
I have the exact same truck that you have, with both upper and lower stable loads and Rancho 9000's. I added uppers first and they did nothing to raise the back end, but did eliminate some sway. Then I added the lowers and it lifted the back a little over an inch, so now I have about 1 1/2" of squat with no water on board. With full tanks and loaded to go, I'm back to about 2". This is pretty good, but I am interested to see how the bags work out for you because ideally I would like some adjustability.
As far as the stableloads damaging the lower overload, I can't see it happening on our trucks. That spring is incredibly thick and tough. I think the stable loads would get destroyed before the spring. They seem to be made of softer steel. Time will tell. Springs are not that expensive, so it's a cheap fix some day in the future if necessary.
I added Rancho 9000's last. The stock shocks had 46,000 miles on them and it was not ideal. I set the back's at 9 and the fronts at 6 and the ride is much more stable. When road condition cause the load to sway, it now recovers with one move instead of wobbling. Don't know if they will last based on some reports from others, but I'm happy with them now. All the shocks I researched had reports of failure, so it's hard to know if these are more or less reliable than the other choices.
Please let us know how it works out with the air bags.
โMay-17-2014 11:24 PM
โMay-17-2014 09:55 PM
โMay-17-2014 09:04 PM
โMay-17-2014 02:54 PM
ah64id wrote:
I know several people who have put the 5100's on with great results with a TC..
Personally I won't ever run the RS9000 again, all hype in my experience (several sets on multiple rigs, thou never a TC.. had long since abandoned them before a TC hit the family).
โMay-17-2014 01:52 PM
