Crumm
Jun 15, 2015Explorer
Better lower overload spacers
I recently installed lower StableLoads but found them not to my liking. Several things I don't like about them including rattling pins, steel on steel wear, rust and ugly. Going to put them up for sale.
The better route for me was some Energy Suspention 9.9117 bump stops. They are 1" thick polyurethane with a stud on them to hold in place via the hole in the spring that the StableLoad used. To install I just jack the back of the truck up a little(which I had to do to engage the StableLoads)with a floor jack under the trailer hitch and drop them in through the holes. Don't even need to put nuts on them as they can't get away once the Jack is dropped. After using them on a few trips I decided I wanted a little more so I used a hole saw and made some 1/4" thick X 3" diameter washers out of some scrap UHMW and slipped them on the stud. No rattling, quicker install and removal than messing with those little pins/keepers and no wear on the springs. You can get them on Amazon for $16 a pair(need two pair). The picture they show on Amazon for a 9.9117 is wrong. They look like this -
![](https://www.energysuspensionparts.com/prodimages/energy_suspension/99117/360/99117_black-360-small-01-01.jpg)
