- brooks379Explorergelled up , wax dropout, icing...its all the same.....truck isn't going to start.
- nevadanickExplorerThe reality is that the fuel probably hasnt gelled up but the wax in the fuel at low temps plugs the filter. But that is a different matter that a different post could add several more pages to this forum.
- brooks379Explorermpierce, I am talking about fuel everywhere we run 48 states and Canada ! NEVER just go with fuel that someone tells you is blended. I have been running diesel trucks for a long time and have seen drivers freeze up (gel) in WY and MT, Edmonton Alberta and many northern states and they say....he said it was treated...
Bottom line is...When it gets below 10 -5 degrees put some anti gel fuel treatment in your fuel or take the chance of gelling up !! - nevadanickExplorerCoolbreeze, treat as in add something like Power Service or Howes antigel or a similar product. I always use Howes when the temps will get below 0. I have been driving dsl pickups since 1985 and have yet to this day have a problem with fuel in the winter in a pickup. I have had problems in equipment.
- mpierceExplorer
gmcsmoke wrote:
Engineer9860 wrote:
The OP's posts in the threads he participates in do not reflect the crass nature of his profile comment.
-jus sayin'.
FWIW, and to anyone thinking of asking a similar question, diesel fuel should be winter blended all the way south to Miami.
but doesn't the location dictate the level of blending required?
EXACTLY. Is it blended or not, is a bad question. The question is: To what level is it blended?
A "blended" fuel in Kansas, is NOT the same as a "blended" fuel in Minot ND! You take that blended fuel from KS up to Minot at -35F, and it WILL not work. - gmcsmokeExplorer
-jus sayin'.
but doesn't the location dictate the level of blending required? - coolbreeze01Explorer
J2 wrote:
We are headed south Wednesday from Pa to FL. with this cold snap. Where about dose the blended fuel stop being used. This would be helpful so I can treat the fuel on the way down. Plus know when to start treating on the way home.
Thanks
Treat? - Engineer9860ExplorerThe OP's posts in the threads he participates in do not reflect the crass nature of his profile comment.
-jus sayin'.
FWIW, and to anyone thinking of asking a similar question, diesel fuel should be winter blended all the way south to Miami. - brooks379ExplorerIf the temp is 10 degrees and above don't worry about your fuel when they are calling for temps below 10 degrees star putting Power Service or FPPF in with your fuel . I have seen many trucks gelled up because someone told the driver it was "winter blend" . Trust me, I have been spending a couple hundred thousand dollars a year on diesel fuel in big trucks for many, many years.
- BumpyroadExplorer
gbopp wrote:
I'm guessing some of the members are talking about the comment in the OP's profile:
'I do not know or care about you, so leave'
Nice.
that was posted 23 minutes before the "what, me worry" post.
bumpy
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
