ksg5000
Nov 07, 2019Explorer
docnascar wrote:
Well, I chickened out and used the pink stuff. I am considering blowing out the lines again to remove most of the pink since the lines and valves have been flushed. This is in hopes to reduce the amount of effort it takes to remove that pink stuff taste in the spring time. Now that I know the valves and water pump dont have any residual water in them I won't worry.
I'm thinking between the lower amounts of residual pink coating the lines and using baking soda in the spring, it will be easier to remove that taste.
That's a first. Once you put the pink stuff in you might as well have left it for the winter. Next time around just blow the lines correctly and anybody who says you have to blow the line and add pink stuff doesn't know how to blow the lines.
44,030 PostsLatest Activity: Jan 20, 2025
