brake shoes
dessa1930
i have about 10k miles towing on my 33 ft tt
thought i would check the brakes and pulled drum of
to my surprise i only one wheel had any brake lining left
i was stopping with only 1 wheel brake
do brake shoes not last that long on a tt
80% of travel is on interstate so i dont use them that much
they have never been overheated or never notice them dragging or running hot when on road
is this normal
16 REPLIES 16
QCMan
Nomad III
Nomad III
You did not say how old the trailer is but an awful lot of trailers have been produced with manually adjusted brakes and then lots more with reverse adjusting brakes. The newer forward adjusting brakes tend to be better but a yearly check when you repack the bearings and put a new seal in can give you an insight into how well adjusted your brakes are. You seem to have one that was adjusted too loose compared to the others and that is why it still has material left.
When was the last time you checked them?
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
WayneAt63044
I find that unusual. Did you buy the trailer new to know the brakes only have 10K miles on them? I find the self-adjusting version run warmer as the shoe is always rubbing and have replaced mine with manual adjust versions.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
