kgie1217's avatar
kgie1217
Cable TV fuzzy...trouble shooting..
I have a 2016 Crossroads Sunset Trail 250RB. Took our camper out this weekend and the site we were at has cable TV hookups. I hooked up the cable to the camper and it was very snowy and fuzzy. I tried two more cables and the same issue. I had one of the camp hosts come over and check their signal and it was good. I even bypassed the camper all together and ran the cable to the back of our outside TV and it was crystal clear. So, below is what I did to trouble shoot the problem:
1. Took the cable connection box off of the back of the camper and tightened all cables. Tested the cable inside the camper and still fuzzy.
2. Removed the splitter from inside the cabin and tightened all connections. Tested cable again and still fuzzy.
3. For kicks I swapped the cable from the back of the camper to satellite and connected the satellite cable to the TV. That cleared up the cable considerably.
4. The TV splitter inside the cabin has some electronic board on it. So, I bypassed all that and hooked the cable up directly to a standard home style two to one cable splitter. When I did that the cable cleared up and no issues. So, it seems the splitter inside the cabin may be bad.
Below is the picture of the splitter inside my camper. As you can see it has an electronic board on it that splits up the signal to the cable or TV antenna. My feeling is that this splitter is bad. Biggest question is...where can I get one of these? My local dealer is backed up until December on service work. Since I'm camping in two weeks and the week of Thanksgiving I'd like to get this resolved before the 18th. Any ideas or suggestions would be highly recommended.
