โJul-06-2013 12:35 PM
โJul-29-2013 04:38 PM
Nvr2loud wrote:
Same with locking lug nuts, if I wanted your rims I would just smash your window to get the key... then you would be missing all your rims and have a smashed window LOL.
โJul-29-2013 02:28 PM
Doug33 wrote:
Regarding the nitrogen question, I regard this as a gimmick. Especially since "air" is 81% nitrogen to begin with.
โJul-29-2013 07:28 AM
JIMNLIN wrote:
Older 14" Marathons (others brands also) came in a load range B at 35 psi which was basically a P tire.
With a 6k gross weight divided by 4 tires = 1500 lbs per tire requirement. Subtract 500-600 lbs hitch weight leaves 1375 lbs on the axles. A ST205/75-14 C at 50 psi and 1760 lbs of capacity would be a good choice for a tire when replacement time comes.
โJul-29-2013 07:08 AM
โJul-29-2013 06:49 AM
โJul-29-2013 06:43 AM
โJul-29-2013 06:13 AM
โJul-29-2013 05:38 AM
subcamper wrote:Nvr2loud wrote:W.E.BGood wrote:Nvr2loud wrote:
My tires have a max rating of 35 psi
Does that seem low?
They are Goodyear marathon trailer tires and I was surprised to find such a low pressure rating
What kind of TT do you have and what is the trailer's recommended inflation (per tag or manual)?
The rating plate in the side of the trailer is sun faded but the trailer is an r-vision trail cruiser 30QBSS
According to a used-RV web site your trailer has a gross weight rating of about 6K lbs. It also lists the tires as 205/75R14. Goodyear Marathons in this size are load range C and the max inflation pressure is 50psi. Are you sure about the 35psi max? The tire rack doesn't even list a Goodyear Marathon in any size with max inflation pressure less than 50psi.
Steve
โJul-29-2013 05:36 AM
Doug33 wrote:
I have an tire inflator compressor, and it is supposed to supply up to 100 PSI, but it takes quite a while to get a tire to go from 45 PSI to 50 PSI. I can't imagine trying to get them up to 65 PSI!
โJul-29-2013 04:59 AM
Does that seem low?
โJul-28-2013 09:16 PM
DiskDoctr wrote:Doug33 wrote:
I was following the cold tire pressure rating of 50 PSI on the sticker located on the side of the trailer. I guess I should check the tire itself.
With my last TT, I kept the tires at 50 PSI cold for almost 8 years with no problems.
Tankless compressors do take a while to get up to pressure and/or volume. Try one, even a small one, with a tank.
The problem with using the sticker on the trailer, is the trailer has no idea what tires are on the trailer or their specs and performance parameters.
Just keep in mind that just like there are folks out there who have leaking propane line that haven't blown up (yet), not having a problem running with too low pressure without any problems (yet) doesn't mean it is correct or safe. It's more a testament to the forgiveness of the tires themselves.
The exception being if you are highly overrated on your tires.
โJul-28-2013 07:49 PM
โJul-28-2013 07:11 PM
Dick_B wrote:
We get a tire pressure question virtually every week and it's the same question only with a different tire pressure.
You could search this Forum for previous posts OR load it up to the cold pressure rating and drive on; which is what I do.
โJul-28-2013 06:45 PM
