It seems my spring loaded turnbuckles are never just right and are a nuisance to adjust. Has anybody added the 'Derringers' that convert them to Fastguns? If so, are they worth the cost? Thanks J ...
I have a set of the torklift derringer anchorgard turnbuckles. I've never used them (I have the fastguns also) but did try them on the TC. They work just like the fastguns, once you adjust them all you have to do is pull the handle to remove.
So, yes, I think they will save you a lot of adjusting and are worth the money since you already have the spring mounts.
