โJun-21-2004 09:12 PM
We are getting closer to answers I am looking for etc.
โOct-06-2004 03:04 PM
You still have not answered the question. If the big block has more horsepower, why is it not rated to tow more than the diesel?....Since you feel that horsepower is the "only" way to measure engine power, I find it interesting that you can't explain why the lower HP, yet higher torque diesel has the superior tow rating.
โOct-06-2004 02:02 PM
Why do I have to explain tow rating and torque when my post was related to horsepower. The kid said the diesels have more power. If we measured power in lb/ft, the diesel would be superior. But we don't, me measure it in horsepower and regardless of the tow ratings, the 8.1 vortec has more horsepower than any diesel currently offered in a pickup.
โOct-06-2004 11:14 AM
As far as the Italian with no Face (must have lost it shaving), engine power is measured in a term called Horsepower. The 8.1 G.M. engine has more horsepower than any diesel engine offered in a pickup.
You are correct in saying that the vortec 8100 has more horsepower in stock form than any of the 3 diesels available in the US light duty truck market. Now, please explain why that engine is rated to tow less than the (by your standards of engine power) lower powered diesel engines? The reason, of course, is that horsepower is only one measurement of engine power. It is also a measurement that is derived from a formula applied to another form of engine power measurement called torque....AND....Regardless what you say, think, or feel about horsepower versus torque, the diesels have more available torque. It must be that the torque output of these engines has just a tiny bit to do with the irrefutable fact that they are rated to tow more, with all other things being equal.
โOct-06-2004 06:53 AM
Absolutely not. Diesels burn less fuel than gassers for a given job, so they are more economical. And that is why diesels are so prevalent in the heavy equipment.Bert
โOct-06-2004 04:41 AM
Sure, it will burn more fuel, probably break more often, and not last as long..but hey a gas engine COULD be manufactured that would keep up with the diesel. Just kidding a bit Bert. Face it, if there was a realistic way that a gas engine could be developed that made some type of sense for heavy equipment or heavy hauling, we'd have it. Some heavy equipment/trucks costs hundreds of thousands or even millions of dollars, and they all have some form of diesel engine in them. Almost anything is possible, it just doesn't always make sense.
I've owned quite a few aircraft, all powered by gas engines. Certainly for light weight in a piston powered aircraft it only makes the most sense. A six cylinder Cat in a two place aircraft makes as much sense as a 8.1 in a D8.
Our smallest piece of equipment is an ASV RC50, it has a 50hp Cat diesel in it. It is a wonderful piece of machinery for it's inteded purposes. The older, similarly sized pieces of equipment that were gas powered are considered antiques and are almost impossible to sell. Same with some types of boats, if they don't have a diesel or two they just aren't considered as desireable, largely due to safety considerations.
People that make a living with machinery demand the best tools for the job. For years now that has overwhelmingly been accomplished with diesel powerplants. It's not due to slick marketing or misinformed consumers. Why would someone want to burn more fuel and be less safe for goodness sake?
โOct-05-2004 08:03 PM
โOct-05-2004 08:00 PM
Bert, sometimes I swear you argue just to re-read your arguments...
Say what you want about the GCVWR and GVWR of the different configurations, the fact remains....ALL current GM trucks with the Duramax/Allison have the exact same drivetrain, and the same frames, brakes, rear gears and axles for that matter. Therefore, the 1,500 pound higher GCVWR of the dually must be related to something besides the drivetrain capacities. The dually has a higher payload capacity, and therefore, is more likely to be able to max out the GCVWR. I don't believe that's just a coincidence...it's very likely that's the reason the dually has a 23,500 pound GCVWR.
โOct-05-2004 07:56 PM
โOct-05-2004 07:55 PM
โOct-05-2004 07:27 PM
This part of your argument is flawed.
It does not matter which truck/cab configuration you get the Duramax in, all current DMax's are the LLY with 310HP and 605TQ. In addition, all current trucks with the Duramax have the same 3.73 rear gears and all of them with automatic transmissions have an Allison. Therefore, the Duramax will develop that same higher HP at the lower RPMs than the vortec 8100 in all 2500HD and 3500 configurations. The 2500HD and 3500srw trucks both have the same 22K GCVWR that has been available since 2001 with Duramax/Allison and 8.lL/Allison trucks (only when the big block is paired with the 4.10 rear gears). Since it would be nearly impossible to max out the GCVWR on 2500HD and 3500srw trucks without exceeding payload capacity through 5er or gooseneck pin weight, it does not make sense to up the GCVWR's of those trucks with the newest version of the Duramax.
With the 3500drw however, it is more likely that one could get to the GCVWR, while still remaining under payload capacity. Therefore, those trucks are rated for 23,500 pounds of GCVWR with the diesel. So, you have a diesel engine with a 3.73 rear end that is rated for 1,500 pounds more towing capacity than a big block with a 4.10 rear end.
I agree that torque is a different type of measurement than HP, but when you are considering the application of torque and HP in the case of light duty trucks when towing, the low end torque advantages of the diesel overcome the high end HP advantages of the big block.
I was merely pointing out that withALL OTHER THINGS BEING EQUAL
the higher torque diesels have an advantage when towing, even though they have less horsepower.
โOct-05-2004 06:57 PM
With the exception of the 3500 DRW (and then only with the allison), the 8.1 is rated the same as the DMax. Part of the reason, I believe, that the DMax is rated higher in that one case is because it develops more HP than the 8.1 at low rpm.
the higher torque diesels have an advantage when towing, even though they have less horsepower.โOct-05-2004 06:07 PM
โOct-05-2004 04:31 PM
My German friend tells me no one drives a diesel car on the Autobon freeway,the can't keep up.
(Just my two cents)
โOct-05-2004 04:25 PM
โOct-05-2004 03:37 PM
