โSep-05-2017 06:25 PM
โSep-17-2017 04:44 PM
FishOnOne wrote:
Coming from the guy who gets wrapped too tight around the axle...
Grow up old man!
โSep-17-2017 01:37 PM
โSep-17-2017 11:56 AM
โSep-17-2017 10:09 AM
spoon059 wrote:TomG2 wrote:I might suggest the next larger size in underwear... yours appears to be getting tight...
You might want to up your comedic skills.
โSep-17-2017 07:19 AM
โSep-17-2017 06:00 AM
โSep-17-2017 03:49 AM
Grit dog wrote:
Tom, you should take a time out and chill....
โSep-16-2017 10:22 PM
โSep-16-2017 09:39 PM
โSep-13-2017 05:57 AM
Atlee wrote:
I believe you missed one important point. You said your truck has a 3800# RGAWR. Note mine is a 4800# RGAWR. And the same goes for the front axle. That's quite a bit of difference.
โSep-13-2017 05:33 AM
VernDiesel wrote:
I think you missed Atlee's point.
No offense to OP but for the reality of stability & safely towing your truck isn't any more competent for handling a TT than any other f150 that has the same light 3,225 & 3,800 axle weight ratings and 6,900 GVWR regardless of the payload sticker. ........snip.....
โSep-13-2017 05:04 AM
TomG2 wrote:Atlee wrote:
That truck should serve you well. The 5.0 is a great engine.
By comparison, my 2014, last year of the steel body, which has the HD package, and Max Tow package is:
GVWR = 8200
Front GAWR = 4050
Rear GAWR = 4800
CCC = 2286
GCWR = 17100
Wheel Base = 163"
XLT Supercab, 4x4, w/ 3.5L Ecoboost
That is my point. I stalked the Ford sales lots for years and never found a F-150 with payload much over about 2,000 pounds. Now, even the base models with the V-8, like mine, are in that range. The times are changing.
โSep-12-2017 06:19 PM
โSep-12-2017 07:15 AM
GVWR = 8200
Front GAWR = 4050
Rear GAWR = 4800
CCC = 2286
GCWR = 17100
Wheel Base = 163"
