gmw_photos
Feb 13, 2018Explorer
Just to add a little more on what Lynnmor said, my earlier post did not suggest avoiding inspection.
I certainly meant to imply the opposite. You really do have to stay after these these things. You MUST be proactive. Leaking seams destroy more RV's than any other single fault I would guess. It's a shame too, because seam maintenance is actually quite easy. A little time consuming and a little messy at times with dicor, but it's a needed process.
And again, if your mechanical abilities are not up to doing bearing, brake and suspension maint, then find a local shop. Most cities of any size would have a trailer shop. Not a RV dealer, I mean a shop that sells and services trailers like utility and cargo trailers. If you are in a rural area, check with the local AG equipment dealer. They may be willing to work on it, or can give you the name of someone as a recco.
44,029 PostsLatest Activity: Jan 20, 2025
