smkettner wrote:
While moving water can most certainly freeze I think the idea is the moving water will bring some heat from the source to avoid freezing. Not sure why people run the cold water.
As someone who grew up in a northern clime, let me explain: water running very slowly down a pipe requires longer time at lower temperature to freeze than water that is just sitting there. And the point is that even though the cold water is cold, it is NOT freezing cold, thus "warm" in comparison to the ambient.
I've lived in houses here in Virginia where the water pipes were foolishly placed in exterior walls. In those houses, there was no way to keep those pipes from freezing except leaving the water trickling when the temperature got below freezing for long periods. On several occasions there were several days in a row where the overnight low was in the single digits and the daily high was in the 20s, and the trickle prevented a freeze. I'm certain of that because once somebody shut off the second floor bathroom sink trickle, and that lone faucet froze up, but none of the others did (we had two bathroom sinks in that house on the second floor -- the one in the other bathroom was fine.)
