rowekmr
Jan 01, 2014Explorer
Ford SD/Excursion 4x4 Driveline Questions
When I bought this truck one of the hubs was slightly hanging out so I knew I would need hubs so I had a shop replace both hubs they found a vacuum line leak that they patched and said 4x4 worked. I picked up in the fall and didn't get a chance to test it but recently when I tried the HVAC went from vent to defroster and I didn't notice any changes in the steering effort so I knew it wasn't working (vacuum leak). The shop told me to just put the auto hubs in manual and that there is probably a vacuum leak in the front axle seals. I did that and found out that I still had to put the dash switch on 4x4 to engage. I tried it in a snow filled lot and could tell the difference.
What does the dash switch do?
What happens in the hubs to engage 4x4?
What else is engaged/turning in the front driveline when in 4wd compared to 2wd?
Is I harmful to drive with the hubs locked and the dash switch on 2wd?
What wears or what damage happens if it is driven in 4x4 on dry surfaces?
Does driveline binding only occur in sharp turns?
