Dusty_Boots
Feb 13, 2021Explorer
Gray Water not empty, only 1 gate valve
2007 six-pac D650 cabover, do you have any information regarding the 38 gal gray water tank, I have only one gate valve for the black water holding tank, the gray water tank does not have a separate gate valve and the g/w electronic indicator still registers full. Not sure if tank is empty after dumping? Do you have similar problem?
