crosscheck's avatar
crosscheck
Aug 25, 2016
Happijac 4600 jack broken
Lifted the TC onto the truck today and when raising the jacks after the TC was in the truck bed, one of the jack legs just dropped to the ground. Would not go up or down although motor seemed to work. Took the jack off the TC and took it apart. Looks like the pin that holds the screw jack on the black inner section to the gears that are attached to the motor has sheared plus a black thick "O" ring on the round retainer cup that the screw runs though has been damaged.
Anyone have ideas on how to repair? What to use for a pin? Where to get an "O" ring to replace the damaged one. How to remove "C" retainer clip on gears above screw so the screw can be attached back to the gears?
Any help is appreciated.
Dave
