Mote
Aug 06, 2013Explorer
Help installing stable loads on 96 dodge ram
I received my stable loads yesterday. I got the A7200 model for the overloads that are on the top.
I drilled the holes in the current stops as instructed. When I tied to put the stable loads in place they don't fit. The front ones almost fit they have about an 1/2" of interference with the overload spring. The rear ones have a lot of interference. I'd have to but about 1/2 of the rubber off the stable load for it to clear the overload spring with the truck sitting unloaded.
Those of you will older dodge trucks did you cut off the rubber to fit in place or did you jack up the truck and slip it in without cutting off anything?
My thought was that if I don't cut off anything then I'll be compressing the overloads quite a bit even when I'm not loaded at all.
