โJun-01-2019 12:16 PM
โJun-08-2019 05:09 AM
zulu52 wrote:Now that everything is working I would check the output of the converter to make sure it is not over charging the battery being plugged in all the time . As far as the old battery , cells can and do just fail .
Update!
I pulled the battery and put it on a charger. It totally fried it in about3 hours. Smoke was coming out of it!
Bought a new battery and installed it today.
Now everything works!
It certainly was the battery.
Thanks for all the input.
Zulu
โJun-07-2019 04:12 PM
TxGearhead wrote:zulu52 wrote:
Update!
Zulu
I just smoked 2 trolling motor batteries on my bay boat. They were 5+ years old and about due to die.
Congrats on being the one who is building the Alamo cannon carriage. The now ex-Alamo public relations lady spoke to our Liberty County Historical Commission last year. I read about the cannons getting restored. It's all a bit controversial but probably best.
โJun-07-2019 10:54 AM
zulu52 wrote:
Update!
Zulu
โJun-07-2019 10:31 AM
2chiefsRus wrote:zulu52 wrote:
My first suspicion is the age of the battery. It is 3 years 8 months old.
It has been hooked to shore power it's entire life while at home.
Is it a bad thing to leave the trickle charger on all the time?
Zulu
I thought you said that the outlet you were plugged into wasn't working? If that is true, depending upon how long that was, it could definitely cause a totally dead battery with a premature death. 3 years 8 months isn't really old for a battery depending upon the type of battery.
โJun-07-2019 08:51 AM
Zulu
โJun-07-2019 06:46 AM
โJun-07-2019 04:19 AM
zulu52 wrote:
Update!
Zulu
โJun-06-2019 07:37 PM
โJun-03-2019 11:38 AM
โJun-02-2019 10:31 AM
โJun-02-2019 08:19 AM
zulu52 wrote:
Every time there is a voltage change, like turning on a light, the gas alarm sounds, then goes off. Propane has been shut off for 10 months.
I don't have any idea how to even trouble shoot this.
โJun-01-2019 03:00 PM
โJun-01-2019 01:29 PM
CA Traveler wrote:2chiefsRus wrote:X2
check for bad battery - everything that works is 110 volt, everything that doesn't work, works off of 12 volt. Maybe your battery went completely dead while it was plugged into the bad outlet.
take the battery to have it load tested at any auto store.
And don't run the A/C on a 100' extension cord.
โJun-01-2019 01:14 PM
