cmack wrote:
Just a word on HP and torque ratings... what matters is at what RPM those numbers are made. A V6 may have the same or better numbers than a V8 but the V8 will generally make more HP & torque at lower RPMs (comparing non turbos) and that's what is needed to get moving from a dead stop. Rear end gearing also plays into how well a vehicle will tow.
:R
Yeah, right…
Its a good thing that the turbo folks never had to drive a vehicle before turbos were invented...
For what ever reason folks who tend to point out some supposed “flaw” of a non turbo gas engine having to run “high RPMs” in order to make max HP/TQ as a totally bad thing, they just don’t get it.
For MANY years Ford had a 300 CID inline 6 which while it didn’t have tons of HP, it had CONSIDERABLE torque and it was really a “bullet proof” engine that just ran and ran. It WASN’T FAST but it got the job done for MANY. That engine for MANY YEARS was the CHOICE engine for MANY SPRINT CAR owners to build up for racing.
Perhaps back in the days of three speed transmissions you might have been “right” but now days with 5 and 6 speed transmissions there is often a very small RPM spread between gears which means the engine RPM will be optimized better to the engine.
YES, that non turbo V6 is going to run higher RPMs more often but it will not hurt it.
YES when it does that it will use more gas (keep in mind the turbo ecoboost engine mileage DROPS to the SAME amount under heavy boost as a non boosted engine making mileage to be a moot point).
YES when that happens you will hear more engine noise.
NO it is not going to hurt the engine.
Would I load a V6 with 10K, NO but I do feel that the V6 is NOT LIMITED to a POPUP and it should be FINE with a HARD SIDED trailer as long as it is kept within a REASONABLE WEIGHT.
At the SAME time I would not even CONSIDER loading a turbo charged V6 (like the ecoboost) with a 10K load. Why you ask?
Simply put, you ARE putting a lot of strain on a smaller lower displacement engine that has many more complex (and expensive) parts, effectively FORCING the engine to work harder than a larger displacement non turbo engine (6.2). The ecoboost engine HAS to give off the same amount of HEAT in a smaller package, that in its self is an oxymoron when it comes to longevity.
That is why I mentioned 7K lbs – 8.6K lbs as ABSOLUTE MAX LOADED for the OPs vehicle, this would give you a trailer of say 5K-6K empty. There is MANY DECENT sized trailers in this weight class, heck the trailer I currently have is a 26ft 1980s and it weighs in at 5.5K empty. My first trailer was a 20ft 1980s and it weighed 3600 lbs empty and filled with our gear plus passengers in the truck we were upwards of 5K, the 97 truck we had pulled that pretty darn well.
The vehicle the OP has is no worse than many folks who are towing with small V6 SUVs and I don’t see those folks just towing popups. In fact the OPs vehicle is a BETTER towing “platform” than most SUVs.
I would go as light as possible but I would not say that the OP is limited to a popup like other folks contend.
